Indesit WIA121
  • #25710
    bigkid
    Unable to cancel program. Handbook says turn dial to (I) position (12 o’clock), wait for all led’s to flash then switch off again…. ?
    Dont you just love them?
    Not seen one of these before are there any falt codes etc posted?
    Regards
    Tony
    #207147
    Re: Indesit WIA121
    Not seen one of these yet so cannot help, however looking at the model description on Partfinder was quite illuminating.
    ‘ CC33742 PROD SEPT2005 EVO2 CONTROLS LOW-END 1200RPM’
    Nuff said. 😥
    bigkid
    Re: Indesit WIA121
    Ta anyway Jim, the thing went out of warrenty end of January.
    Looks like its down to Indis##t.
    Regards
    Tony
    #207149
    Re: Indesit WIA121
    Hang on in there, you may get some more informed answers later. 🙂
    #207150
    Re: Indesit WIA121
    bigkid wrote:Unable to cancel program. Handbook says turn dial to (I) position (12 o’clock), wait for all led’s to flash then switch off again…. ?
    The user booklet also adds…… “If another programme is not selected the door lock LED will remain lit for about another minute”
    Also, in the ‘Troubleshooting Guide’ it mentions…. “remove the plug then wait at least 40 seconds before reconnecting”
    HTH? 😕
    #207151
    Re: Indesit WIA121
    Tony,
    Turning the knob on 12 o’clock position while is working will reset. 😳
    Turning (or keeping there) the knob on 12 o’clock position at the end of the programme will go on “Stand By”. 😕
    To start another program turn knob to desired program and push “Start/Pause” button. 😉
    Baron 8)
    Jim, can I send to you one picture for reading error for “Low End”?
    #207152
    bigkid
    Re: Indesit WIA121
    Thanks Baron, but that was the problem. Turned knob to 12 o’clock and it carried on with the orig’ prog.
    Couldnt find a way to abort it.
    Unpluged for at least a minute, drained the water with a fly lead to pump. Opened door, restet a new spin prog and same again.
    Just waited till spin had finished.
    The orginal fault was that the door lock light decided to start flashing when the machine was switched off.
    If I had hair I would be pulling it out.
    Will wait to hear from customer and keep you posted.
    Tony
    #207153
    Re: Indesit WIA121
    bigkid wrote:The orginal fault was that the door lock light decided to start flashing when the machine was switched off.
    But you don’t have “On/OFF” button. How to swich OFF. Led from door lock is flashing when is not yet open… so he don’t go on “Stand By” mode…
    In order to be one fault signal should flash also other Led’s as well. 8)
    #207154
    helo_75
    Re: Indesit WIA121
    no no no no no no
    lol, had LOADS of these in the field doin that
    it needs a new eprom and board
    its common, sorry
    the eprom isnt displayed on partfinder, but if u type in eep in the searchpart bit, it does come up
    hope this helps
    #207155
    Re: Indesit WIA121
    Sorry Baron, I think I must be misleading you, the line I posted is the description of the machine on the manufacturers own software.
    Low end is a term used in the UK for basic, cheapest, ( naff) 😉 items, 😀 Low end as opposed to top end of the market.
    Re: Indesit WIA121
    its common, sorry
    One EPROM damaged can cause two types of symptoms: Not finish one program (stuck on one step) or when is totally damaged even physical gives error F9 (most common).
    Case when is not resetting at point position but can in other then EPROM contain wrong program (is not compatible with programmer not allways gives F9 or F6).
    iadom wrote:
    Low end is a term used in the UK for basic, cheapest, ( naff) items, Low end as opposed to top end of the market.
    Ok, but exist variant of PCB at Indesit so call “Low END” (model WIA) which is this case only behind of fascia board like Hotpoint.
    #207157
    bigkid
    Re: Indesit WIA121
    I think I’ll ask Tony at EMW if he has any vacancies, this looks like a good little money spinner.
