Indesit WIA121 Auto – Module Fault?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIA121 Auto – Module Fault?
  • #35865
    MickGeorge
    Hi folks
    Been to this today and suspect module fault.
    Door locked all the time(can only unlock door by unpluging) wash,rinse lights on all the time with spin light flashing. Press start/on/off – click and slight hum from module and nothing else only wash, rinse and spin lights on all time.. would suspect pos motor fault but door locked all the time – what ever prog is selected.
    If this is module what is involved in changing one if I cant get px from WMW?
    The module is “L” shaped and fitted behind control pannel. Machine only 14mths old.
    Is the anything else that could cause this or is it just another crapy Indisit module? 😯
    Mick
    #248448
    helo_75
    you got it
    without a word of a lie, i reckon ive changed 70 of them modules on those
    ull need an eprom too, and its well hidden on partfinder
    id check the brushes first, though
    #248449
    Re: Indesit WIA121 Auto – Module Fault?
    MickGeorge wrote:Door locked all the time(can only unlock door by unpluging) wash,rinse lights on all the time with spin light flashing. Press start/on/off – click and slight hum from module and nothing else only wash, rinse and spin lights on all time.. would suspect pos motor fault but door locked all the time – what ever prog is selected.
    Mick,
    I don’t believe that you are inside AutoTest…
    just try after switching “ON” by “ON/OFF” button and turn selector to “12h” position… in order to reset himself…
    If he’s continuing his job after that, this mean perhaps that your program selector is out of order… (in order to see that, and also you have available second selector swap them… this is only for diagnose… do not let them so because you will have problem with parameters which is selecting the second…)
    #248450
    robbo1973
    I agree with helo i have changed loads of these. emw repair them
