indesit wia121uk
  • #29740
    robbo1973
    this machine is the newer type with large board at the top.the cust says it goes thru wash then all of a sudden the door locked light ,anti crease and the middle programme stage light (rinse) starts to flash rapidly. are there any fault codes for these.
    cheers chris.
    #224293
    robbo1973
    Re: indesit wia121uk
    no takers are there any fault codes or do i need hardware key ❓
    #224294
    Can you identify the two lights excluding the door lock by number. If this is a late machine then the hardware key that is available to the trade will not work. There is a MK2 version of the key for recent models. 😥
    senseib
    Had a couple of these m/c in the past – both pcb! Sent the modules away to EMW to repair. Probably the same here Iam thinking!
    Wouldn’t put much store by the fault codes on this machine.
    Hope this helps,
    Brian.
    #224296
    robbo1973
    thanks for replies lads.the lights are door locked, there are 2 option buttons on this machine and i think it is the right hand one and it has 3 progress lights away from option lights and the rinse is the middle one.
    thanks chris.
    ps quite a new machine about 1 and a halfish she thinks it does not have the normal rubbish board at the bottom corner but a main board behind front facia.
