My Indesit WIDL126 is flashing extra rinse and spin lights.
When the pump starts to drain water continuously keep filling and draining at the same time. I had to switch off the machine to stop that. I checked the tube that fits to the water level sensor, I removed it from the sensor and blown through it, air is passing comfortably passing through. Is there any other way to check any blockage? Is the sensor faulty? or is there any other problem?
Please advice.
Please keep it to one thread or things get confused.
Someone will help as they can however if you look at the lights position you will be able to glean the fault code being displayed. What they are labelled as is pretty much meaningless in most cases.
I think, but I’m not sure, that these error codes will apply to that model:
