Indesit WIDL 102 Limited Prog Selection ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIDL 102 Limited Prog Selection ?
  • #27872
    Turbo
    Could any one please help on this one.
    This washer dryer will only allow you to select prog 2,4,12,Rinse Cycle and Drain.
    If you move dial to any other prog then all 5 lights horizontally flash along with dryer light which is the lowest of the vertical sets of lights.
    Have checked both elements, fill coils etc. Filled machine up and checked wash action on prog 4 which seemed ok.
    Hope someone can help please !
    Turbo
    #215952
    helo_75
    well, lights 1,2,3 &4 is f15 – dryer heater relay fault
    nevere seen all 5 flash
    looks like a pcb fault to me
    hope this helps
    #215953
    Turbo
    Re: Indesit WIDL 102 Limited Prog Selection ?
    Thanks for the reply, does the new board have to be programmed ?
    Turbo
    #215954
    helo_75
    nope, but you’ll need to fit a new eprom, or change the one over from the original board, to try and save costs
    #215955
    Turbo
    All ok now got EMW to put eprom in new board.
    Thanks Turbo
