indesit widl 126 dryer fault
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit widl 126 dryer fault
  • #24712
    funbobby
    hi no heat on dryer,ive tested the element and thats fine.wondering if its the stat or some themal type fuse fault? any help much appreciated.
    #203062
    Re: indesit widl 126 dryer fault
    funbobby wrote:wondering if its the stat or some themal type fuse fault?
    It could be? And you can’t rule out the main Module board either at this stage. 😥
    #203063
    funbobby
    is there a way of testing the stat?appears to b a wire running from stat to a connector block which is open circuit is this the thermal fuse wire?
    #203064
    Dave_Conway
    funbobby wrote:is this the thermal fuse wire?
    Yes 🙂
    This post will help, it’s basically the same machine:
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=15734
    #203065
    funbobby
    cheers dave
    #203066
    funbobby
    right got the new fuse but im assuming its gone for a reason?from other posts i gather the venting could be full of fluff anyone clarify?
    #203067
    Rear duct full of fluff, fan full of fluff, fan motor not running, no cold water condenser feed and earth leakage on element can all cause the thermal fuse to fail; as can stopping it and opening the door before it finishes.
    funbobby
    hi penguin thanks for reply but is one of the above more common than the rest.i know the cold feed is ok and fan is working just not had chance to check for fluff. missus is bending my ear! many thanks
    #203069
    helo_75
    theyre all common
    its an indesit after all
    just generally check for fluff blockages and/or things not functioning
    condenser blocked is probably on the money.. but id get someone in, i once cut myself real bad getting one of those out, theres a LOT of sharp edges in there, and takes some experience getting it out
    and i wouldnt be surprised if you fitted the fuse and it worked ok
    keep us in a job, merloni!
    hope this helps
    UNPLUG if u want to investigate, and wear thick, protective gloves
    #203070
    funbobby
    cheers helo
