Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › indesit widl 126 flashing lights 2+3+4
- This topic has 30 replies, 5 voices, and was last updated 18 years, 1 month ago by
blaster.
March 3, 2008 at 7:50 pm #35021
blaster
Participanthas subjuct says my indesit widl126 washer drier stops on peogram 11 short wash while its filling and rinsing and the red power light is flashing with these other 3 green lights easy iron/extra rinse/1200 600 spin from left to right these or light 2 3 and 4 anyone know whats wrong, i did find a coin in the filter which ive taked out and checked all the drain pipe does anyone have a list of fault codes for this troublesome washing machine, looks like i might need them lol, its only 10 months old by the way, fault does seam to have cleared and got it running again but if anyone knows what this fault was pointing too it would be good to know for future refference.
March 3, 2008 at 8:02 pm #244821iadom
ModeratorRe: indesit widl 126 flashing lights 2+3+4
2,3 & 4 (FO7) is supposed to signify a heater relay fault. It is more often F08 that points to heater relay fault though.
If you type ‘Indesit AND eight AND flashes’ into the forum search engine you will get all the reading you need, don’t have nightmares, :rolls: 😉
March 3, 2008 at 9:31 pm #244822blaster
ParticipantRe: indesit widl 126 flashing lights 2+3+4
its been a while since i repaired washers for a living, but had a indesit for 10 years very little problems, i did here about problems with this model didnt know they were so wide spread, its washing away again now so will keep a eye on it, do these washers come with just 1 years warranty, i wonder if taking out a extra warranty might be worth while, i only paid £151 for it brand new 9 months ago but still hoped for 3 years use before replacing it.
March 3, 2008 at 9:36 pm #244823hotpnt
£151 new?, and you want it to last 3 years?, hmm,
March 3, 2008 at 9:43 pm #244824blaster
i dont think 3 years out of a new appliance is unreasonable , regardless if i paid £151 or the retail price of £299, ok if i got 2 years i probably would be fairly happy, but 9 months, but has i said its washing again but has ive found out there’s no point getting anything really cheap if its unreliable, its all these electronic b@llocks, there always the first thing to fail, when i used to be in the trade some brand new washers had lcd displays and electronic controller’s instead of the mechanical ones and they were very poor regarding reliability, do all new washers have electronic programmers in them now?
March 3, 2008 at 9:49 pm #244825helo_75
Participantyup nearly all machines have electronic controls
here go the consumer rights brigade
want 5 years warranty on a £151 machine, but quite happy to pay £500+ to put a £25,000 car through an mot after 3 years
is it really that hard to be realistic?
March 3, 2008 at 9:49 pm #244826blaster
found this on another forum hope it helps others
widl codes – light flashing from left to right are numbers 1-4f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power boardf1 and f17 share the same light
and this is what they meanF01 Short Circuit-Motor Triac
F02 Motor jammed or tachogenerator detached
F03 Temp probe o/c or s/c
F04 Pressure switch jammed on reset
F05 Pressure switch jammed on trip
F06 Programme selector management error
F07 Heater relay stuck
F08 Heater relay cannott be activated
F09 Incompatable eeprom
F10 Pressure switch not sensing correctly
F11 Pump cannot be be activated.
F12 LCD Display module and main module not communicating correctly.March 3, 2008 at 9:52 pm #244827helo_75
Participantlike that wasnt posted 2 years ago?
March 3, 2008 at 9:57 pm #244828hotpnt
always seems odd, some people go food shopping and avoid the stripey value products cause its clearly rubbish, then go next door and buy a machine for under £200 and complain when it fails in the first year!
March 3, 2008 at 9:58 pm #244829blaster
Participanthelo_75 wrote:yup nearly all machines have electronic controls
i dont expect a 5 year warranty but did read indeshit gave a 5 years parts warranty if so might be usefull to know thats why i asked, has for your car senerio, i see the point your trying to make but using your maths equation paying 1/50 the cost of the car to repair it after 3 years would be the same has me paying out £3.02 to fix my washer so not really the same is it, has if the main electronic panel has gone faulty the cost would be £90 just for the part to fix my washer. Im also sure that fault list was posted on here 2 years ago but when i did a forum search it didnt appear, also yes i do buy tesco’s value stuff has some of it is good and exact same has better brand but then some is garabage has you say, but im not brand orinentated, i went for the same brand i had previously which still worked after 10 years, ok so i changed the carbon brushes a few times and replaced the door and a few door seals, but that washer is in my shed has my backup washer, like i said if i got 2 years i would have been ok with it, i think 3 years was probably pushing my luck, also by the way i fix my own car lol, £16 for a new track rod end on my 4 year old £22000 car to get it thru this years mot, it went straight thru last year.
March 3, 2008 at 10:02 pm #244830hotpnt
hang on a min, if you bought it 9 months ago brand new, why are you not getting it fixed under garantee??
March 3, 2008 at 10:09 pm #244831blaster
hotpnt wrote:hang on a min, if you bought it 9 months ago brand new, why are you not getting it fixed under garantee??
i will be getting it fixed under the warranty, it must have a least 12 months with it, only problem is looks like the faults cleared it self has its all working again , so now i know what to look at ie heater connections/pcb/heater relay on pcb/wiring to heater, what i will do is have a good look round to make sure there’s no burning on the pcb for instance, i dont want the fault coming back when the washer is 13 months old do i, if i see anything and the fault happens again i will phone indesit. Thanks lads for your help, you probably think im a right tight arse expecting too much from a £151 cheap washer/drier and you be spot on.
March 3, 2008 at 10:12 pm #244832helo_75
Participantso your car was requiring a part after 4 years? and if the part wasnt fitted, it wasnt fit for use on a public road
NOT FIT FOR PURPOSE
id be going back to the car dealer and demand a new vehicle, compensation for the hassle, id be on the net posting on every car forum i could find
people do it for £100 fridges, why not for a £22,000 car?
you all taking my point yet?
March 3, 2008 at 10:13 pm #244833helo_75
Participantlol, dont take all this to heart… weve all detracted from the original post, and at leat the machines working at the mo, and will probably require a pcb and eprom at some stage, its a sticky heater relay
take care
March 3, 2008 at 10:19 pm #244834hotpnt
ok, but be carefull what your playing with in there, you dont want to invalidate your garantee
