Indesit WIDL 126 s flashing error 1,2 and 4
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIDL 126 s flashing error 1,2 and 4
  • #23698
    nikb2005
    Hi all….
    i’m glad i found this forum !
    i’ve had a good read and no one seems to have had this same problem. set onto a normal program will go through to spin cycle and after being at full spin for a few minutes it then ceases spinning and the door lock red led pulses quickly and the green led’s 1, 2 and 4 flash on and off at around 1 second intervals. i have checked the easy bits like blocked pipe and flushed out any pipes i could get off .. when the leds start flashing you can still here the pump for a couple of minutes but the drum doesn’t move at this point ..
    not sure where to go from here .. some one suggested brushes on the motor but it does spin up to full speed before it fails ..
    any help appreciated !
    thanks
    nik
    p.s. isn’t there just a directory somewhere of all the fault codes ??
    #199044
    Re: Indesit WIDL 126 s flashing error 1,2 and 4
    Neons 1,2 & 4 suggest a fault on the dryer side NTC or dryer fan. Could be a simple broken wire to the NTC ( temperature control device) on top of the dryer heater box. Several other possible causes, please remove the mains plug if you open it up.
    nikb2005
    thanks jim
    i have been testing further today and i get the same fault condition if i just set it on a spin cycle on its own ..
    after reaching full speed for a few mins its stops the cycle and shows the leds …
    would this still point towards a dryer fault ?, i will still check the connections though !
    cheers
    nik
    #199046
    nikb2005
    i stripped down the dryer fanand unit cleaned all the contacts and connected again …
    the first full cycle has been a success !!
    so far so good !
    thanks
    #199047
    GavinW
    Indesit WIDL 126 s drying fan not working
    I think I’ve got the same problem as
    http://www.ukwhitegoods.co.uk/modules.p … ly&t=20685
    It’s quite stiff to turn, and a small amount of water just wept out around the top of the spindle! Very odd.
    Is it best to just replace the motor..?
    #199048
    helo_75
    GavinW
    It’s late 🙂
    I’ve got a WIDL 126 S.
    The drying fan has stopped working. Opening the housing up reveals the fan & motor to be quite stiff to turn. Very curiously, a small amount of water wept out around the top of the spindle, past the bearings, when I was playing with it – didn’t expect water anywhere near there.
    I think I’m doomed to just buying a new motor, but wondered if there was anything else to try. Is it a common failure?
    #199050
    Its an Indesit machine, everything on it is a ‘common failure’ 😉
    There is only one long term, satisfactory solution. 😉
