Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Indesit WIDL 126 UK
- This topic has 8 replies, 5 voices, and was last updated 19 years, 3 months ago by
pmb.
December 17, 2006 at 11:54 am #23428
pmb
ParticipantHi i had a look at an Indesit WIDL 126 UK which appears to be working but the door light flashs when the door is not locked (before and after washs). My customer looked in the instructions under troubleshooting which told her to call out an engineer. I have checked all the things i normally check on these but cant find a reason for it, has anyone had this before? these Indesits r frustrating arn’t they all these intermittant faults + not understanding customers = :haier: thanks for any help 🙂
December 17, 2006 at 3:45 pm #198073Dragan
ParticipantRe: Indesit WIDL 126 UK
The best way to check fukcionality of this machine is by means of tester
Housing Seriale EVOII,Indesit order number is C00145046.Regards,Dragan
December 18, 2006 at 12:14 am #198074allround
does the light flash with the program selector knob in the off position . if so this is quiet common and requires the module replacing . have been to many of these with that fault , reprogramed eeprom and still the same so the only cure is the module im afraid
December 18, 2006 at 8:20 am #198075pmb
Thanks alot i will order a new module i am happy to know :salute: and hvala to Dragan those testers sound very handy i haven’t heard of them before i am going to look into getting one 🙂
December 18, 2006 at 9:07 am #198076admin
KeymasterRe: Indesit WIDL 126 UK
Dragan wrote:The best way to check fukcionality of this machine is by means of tester
latest diagnose key?
C00095669 can be used also thrue computer by program LBSat
Which I couldn’t order key from merloni but I have seen it working. If someone can order for me I’m interested.December 18, 2006 at 11:07 am #198077iadom
ModeratorRe: Indesit WIDL 126 UK
The hardware key on its own doesn’t give much more information than the flashing light or digital display error codes. At well over £100 and reported to be rather delicate it seems like a complete waste of money when Indesit refuse to allow you access to the software required to run the diagnositics or reprogram eeproms.
December 19, 2006 at 8:22 am #198078admin
Keymasterwell, I have LBSat soft but not the key.
Baron
I mean diagnose key(hardware key)
December 19, 2006 at 8:46 am #198079admin
And believe me is stupidity blocking this (availability) 😕 because if you want you can use any EPROM programmer in order to rewrite memory’s 😈 . But question is why in this manner? when you can make more easily with proper one? 😉
For example the alarm lights gives you one direction to seek, but nothing forward… with diagnose key and computer you can command any peripheral (motor, valve, pump), see the statistics (which program or optional taste was used; history of errors…) and ,if you need, also one quick memory rewriting. :tup:
So in conclusion you can manage more easily one repair (more starting information= quickly and precision repair).Baron 8)
December 19, 2006 at 10:15 am #198080iadom
It would be very useful to have this information as you say Baron, its just a pity the machines are so poorly constructed that half the time it is not worth the effort. 👿
