Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WIDL 126 Washer / Dryer
- This topic has 14 replies, 7 voices, and was last updated 18 years ago by
mrsbiff.
March 17, 2008 at 6:08 pm #35361
mrsbiff
ParticipantHi, have got a indesit widl 126 washer / dryer, and it appers the dryer part is not producing any heat, so nothing getting dried, just stopped !!! Have tried using the washing machine today, and does not appear to be heating up the water. Anyone any ideas. Thanks in advance.
March 17, 2008 at 6:24 pm #246225Phidom
ParticipantRe: Indesit WIDL 126 Washer / Dryer
The heater for drying is different to that for washing so the 2 faults are probably not related. If the washer is not heating I would generally expect the machine to stick on wash and never continue on to the rinses. Is this what’s happening?
March 17, 2008 at 8:02 pm #246226mrsbiff
Hi, thanks for responding. The machine is not sticking on wash. I have assumed the washer is not heating up the water,as when it was on wash, I could not feel any heat from the door at all, so perhaps I have got that wrong.
The tumble dryer is definatly not producing any heat, the drum goes round as if all is OK, but washing not dried at all. Thanks.
March 17, 2008 at 10:42 pm #246227mrsbiff
Just ran the washing machine through on a hot wash, and the water is heating up, so problem is just with the tumble dryer. Any thoughts anyone. Thanks in advance for any advice.
March 18, 2008 at 12:15 am #246228Penguin45
You need a test meter and the knowledge to use it. The dryer heating elements and safety fuses fail regularly – you need to perform a resistance test looking for a reading in the order of 20-25 ohms when the heater is split from the circuit. The safety fuse should read virtually no resistance. If you can’t do this, you should get some professional help – guessing what might be wrong can prove to be an expensive way of repairing an appliance.
Power off if you plan to investigate this yourself.
March 18, 2008 at 9:14 am #246229mrsbiff
Hi, thanks for that, my husband had the top and back off the machine last night. After looking at your post this morning, he said he could not see anything that looked like a safety fuse, can you point us in the direction of where to look. He has a test meter, so feel OK about him investigating. Thanks once again.
March 18, 2008 at 10:20 am #246230Phidom
If you trace the wires from the heater element you should see they go to small round or square devices mounted nearby. These devices will be either control thermostats or thermal fuses. Each of these will show a short circuit meter reading if working, open circuit if failed. You need to remove one connection from any pair of terminals before testing with the ohm meter or you will get misleading results.
March 25, 2008 at 4:43 pm #246231mrsbiff
Hi, thanks for the advice, have been away for a few days, so will now get back to sorting out the issue.
April 13, 2008 at 7:42 pm #246232absinthe_boy
Have a similar problem with my WIDL126, no heat on the drying cycle.
Have a reading of 40 Ohms across the heating element, which seems higher than normal (?) but not suggesting its broken.
Can’t locate any fuses or similar for the heating system however. With the top off, in the back right corner there’s a white, square plug which connects to the heating gubbins.
Forward on the right there’s a round device that is not directly connected to the heater. What am I looking for?
Machine is just under 3 years old, looks very clean inside though I have not removed the cover to the heating element yet.
Thanks in advance for any help.
April 13, 2008 at 8:30 pm #246233absinthe_boy
Do’h I think I found it….its the inline brown-shielded cable? That has a thermal device under the shielding and its got infinate resistance. New part £12 and I can replace it in a minnute 🙂
April 14, 2008 at 11:01 am #246234mrsbiff
Hi, we will have a look at that, to be honest, not done anything else with it !! Hope it works for you, let me know how you get on.
April 14, 2008 at 5:43 pm #246235Flyman
Thermal fuses do go for no reason but normally you should check the condensor box and fluff filter for blockages.
October 30, 2008 at 12:45 pm #246236aimengsi
Phidom wrote:The heater for drying is different to that for washing so the 2 faults are probably not related. If the washer is not heating I would generally expect the machine to stick on wash and never continue on to the rinses. Is this what’s happening?
Oh yes, My indesit typically behaves like this. so how can I sort this issues ??? 😳
October 30, 2008 at 1:03 pm #246237Phidom
If you take the back off you will find the heater terminals toward the bottom at the back of the outer drum. The resistance can be checked as described by Penguin earlier in this thread. If you get an infinity reading you know that the heater has blown.
December 2, 2008 at 1:41 pm #246238eddimonton
Hiya
I have the same problem but my machine is going on forever! I’m alittle confused over what they exact part is actually called? I’m trying to buy the part but need to know whats its known as!
Many thanks
Chloe -
