Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › INDESIT WIDL 126S UK
- This topic has 8 replies, 4 voices, and was last updated 19 years, 4 months ago by
Marty-K.
December 11, 2006 at 9:38 pm #23295
Marty-K
ParticipantWent to this one today. Switch on to any wash programme and it starts to fill then pump runs intermitantly. After about 30 seconds red light flashes and continues pumping. Unable to reset programme unless socket unpluged. Spin programme works fine and can reset. All componants checked and readings seem about right. Insulation resistance on thermistor 140 megs but i can`t see that this would be a problem. Have i missed something or is this likely to be a pcb problem?
Marty-kDecember 11, 2006 at 9:41 pm #197651Penguin45
ParticipantRe: INDESIT WIDL 126S UK
Sounds like a dodgy p/sw to me.
December 11, 2006 at 9:53 pm #197652Marty-K
Thanks Chris. That was my initial thought, but it seemed to be switching ok with my test hose connected.
Marty-k
December 11, 2006 at 9:58 pm #197653Penguin45
Marty-K wrote:it starts to fill then pump runs intermitantly.
Don’t forget terminal 4 is flood protection. For £8, I’d take a punt and swap it – p/no C00110327
December 11, 2006 at 10:09 pm #197654Marty-K
Sounds like good advice to me, i`ll give it a go.
Marty-kDecember 15, 2006 at 9:42 am #197655Marty-K
Gave it a go, still got the same problem 🙁
About 20 seconds after being switched on red door lock led flashes rapidly, the easy iron led flashes slowly and the dryer components spring into life even without pressing the on button ❗ It looks like an electronics problem to me, unless any one knows different.
Partfinder lists the EEPROM and pcb seperately so presumably I will need both parts and the EEPROM removal tool to complete the repair. Any advice would be appreciated.
Marty-kDecember 15, 2006 at 10:23 am #197656admin
KeymasterPlease tell in right order which LED’s are flashing:
Phase Led(spinning)=Key1=Key2=Key3=Key4
x 1 x x x
From what you said is F01 (“easy iron”LED flashing=motor triac short circuit) is in contradiction with “Spinning program” which is working.December 17, 2006 at 1:48 am #197657Alan1476
HI there
Had this problem in the past. First megger all components seperatly any earth leakage will give you a fault like that. Secondly check for continuity between pressure switch and pcb also tighten the duitones on the module and check the wires on the heater, Give them a firm tug what normaly happens is the cables look fine but break down inside. If a remember correctly they are brown and black (black one normaly breaks). If after all that I looks like a module fault. Note sometimes you can unsolder the EEPROM Be carefull?? And put it in the new module. Otherwise you have to buy a new one of have a blank one re written by a hotpoint indesit enginner.
Hope to have been some help
AlanDecember 18, 2006 at 10:32 pm #197658Marty-K
Thanks for your replys. The customer has gone snowboarding for a week so I guess it`ll be checking it in the new year:rolls:
