Indesit WIDL 126SUK Wrong PCB?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIDL 126SUK Wrong PCB?
  • #72939
    OLLIE2806
    Hi Guys,
    I’ve got the above washer dryer with a PCB fault but the new one i have is missing the J10 connection.
    I have C00254535? Any ideas? Have i got the wrong one or is there some kind of modification?
    The serial number for the machine is 605313160 8035591500
    Thnaks
    #386016
    Re: Indesit WIDL 126SUK Wrong PCB?
    There is a mod, connector C00141769 converts J10 to J13 & J14.
    #386017
    OLLIE2806
    Cracking. Thank You
    #386018
    OLLIE2806
    Im due to fit this conversion kit tomorrow where do the wires etc go? is it straight forward as there is no wirng diagram come with it.
    #386019
    madangler1
    Rite you should have 2 black wires with a connector on one end going to 2 spades. These go to the drier fan motor
    Next you have 4 wires going from 1 five way to two way connectors. They will be two different pairs of colours of wires.
    Looking at the 5 way connector you will notice one one pair of wires are next to each other then the other pair will have a gap between the wires entering the plug.
    The pair with the gap go to the drier inlet condenser valve. The second pair with no gap go to the drier NTC on top of the heater box.
    VERY IMPORTANT get these rite or it will blow the board. The colours of the wires are not reticent as they keep changing them. The wires with the gap separating them go the the condenser valve.
    #386020
    OLLIE2806
    Excellent, Thanks Very Much!
    I take it the Connector from the heater motor just goes squeezes onto J14 on the board? seems a tight fit?
    (im only placing it on a spare PCB i have here just to see how it would go)
