Indesit WidL102
  • #56903
    rocker
    On running the drying cycle, when it calls for water it appears to take in around 2 pints, then after a few minutes pumps it out, refills carries on, the water level is to high, clothes coming out soaking wet, have changed pcb still the same, checked inlet valve only activates when powed up (not leaking) pump working ok.
    can anyone help please.
    John
    #329225
    Allsorts
    Re: Indesit WidL102
    Check that you have the correct supply on the correct inlet valve
    #329226
    rocker
    Re: Indesit WidL102
    Have correct connections & voltage.
    but does the dryer valve have a reducer fitted, cant see one on testing.
    john!
