Re: Indesit WIDL102 control board connections help
Black wires go to dryer fan motor. J14 is the correct position for the connector. J15 puts 240V on the motor, but with no neutral return path when on drying function – be warned, heater element is on though, so gets very hot very fast without fan spinning!
Had problem lately when trying to start a cycle. The lights all go out and machine is essentially dead lest you unplug it a while and then it comes to life once more. Trying to start the cycle again often repeated this scenario. Just found that holding the cycle on/off button in for quite some time brings it back with a reset. Also found that slamming door very hard is the solution to getting the cycle to work instead of making machine go dead.
Dodgy microswitch in door lock mechanism?
