Indesit WIDL102 fills & empties at the same time
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIDL102 fills & empties at the same time
  • #53766
    nelson
    Hi been called to this one, customer claims that when the machine is started it starts to fill but the machine also starts to drain at the same time there are no flashing lights, so no fault code displayed.
    I have already asked them to check plumbing to rule out waste hose syphoning.
    Any ideas with this one?
    #317152
    Re: Indesit WIDL102 fills & empties at the same time
    If you set it to a spin programme and it starts to fill then the PCB is goosed, well known fault.
    clyde
    It’ll also fill and empty if the wiring to ntc is broke!
    #317154
    torxhead
    hi been following the posts.
    what is ntc?
    cheers
    #317155
    lerch
    negative temperature coefficient 😀
    #317156
    A1TEC
    lerch wrote:negative temperature coefficient 😀
    Thermistor. 😉
    #317157
    torxhead
    thanks a1tec. thats my language, lol
    #317158
    clyde wrote:It’ll also fill and empty if the wiring to ntc is broke!
    That should always throw up an error code though.
    #317159
    helo_75
    jim is right, you would get an f3 fault, even the dryer ntc would normally flash an f13 fault
    #317160
    nelson
    😀 Thanks for the replies, I had a look at the board and looked like there had been a bit of action around one of the solder joints. When I ran the machine I could see a bit of arcing between two soldered joints. I cleaned the crud from around the joints and tried it again. It worked fine. Whatever the crud was, it was clearly conductive.
    Thanks again.
