Indesit widl126 don’t start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit widl126 don’t start
  • #37873
    hidoyoudo
    Hello Everyone,
    My washing machine Indesit widl126 does any more.
    When it is plugged into the power of the 4 lights function keys and LED lighting / locked window and saw the flash delay scheduled 9am quickly!.
    I try let the washing machine off more than 24 hours and I always have the same symptoms when I return the socket …
    In browsing the net I read that lights flashing represents an error code. I can not find the code of my failure (4 lights door/lock + delay set 9 hours).
    If someone can get information about the type of error that would be cool so that I can begin to disassemble my machine ..
    Regards.
    Laurent
    #256878
    Re: Indesit widl126 don’t start
    I’m guessing you are in the Swiss area. Some of the technical details will be different from your machine to ones sold in the UK.
    If you can describe the flashing lights by number ( 1st + 3rd, 2nd+3rd+4th for example) from top to bottom or left to right we may be able to hazard a guess as to the fault code.
    hidoyoudo
    Hi Jim,
    Exactely my machine sold in Switzerland…
    The flashing code is :
    from left to right 1st+2nd+3rd+4th + on-off doorlock
    from top to bottom is 4th (9h delay timer)
    Thank you in advance for your prompt reply
    Regards
    Laurent
    #256880
    If vertical light number 4 is flashing then that suggests a motor triac failure.
    The electronics on these machines are known to be very unreliable, they have a poor reputation amongst the UK service industry.
    These codes are only a guide as to the area of the fault.
    It may be a loose wire, or poor connections on the main module situated in the base at the back but in most cases it is the module itself that has failed.
    hidoyoudo
    Hi Jim
    Thanks a lot for your reply.
    You can check my failure in video clip on
    http://www.youtube.com/watch?v=pBA-1r1TBuI
    Regards
    Laurent
    #256882
    It does look as though you may be looking at a faulty module. You would have to enquire locally to obtain parts if you decide to have the machine repaired. The parts software we have access to will differ from the ones for your area.
    Sadly rather expensive parts for a budget machine.
    Jim
    #256883
    hidoyoudo
    Hello,
    I finally disconnect the front printed circuit board, cleaned contacts and power up the machine.
    Everything went OK, so I decided to get through a washing cycle .. it reached the end but during the process, leds have been flashing again.
    But now, unplugging from the mains clears the system, allowing to start a new cycle.
    Not really convenient isnt’it!
    Any others hints?
    #256884
    helo_75
    theres another module
    at the back, bottom left
    it will need replacing, along with the eprom
