lights 1 and 4 and red light flashing sometimes fills and pumps at the same time. panel and connections seem fine, cant reset by unpluging machine for a few minutes just starts flashing again.if anyone can help i would be greatfull. thanks.
Technically, it’s an EEPROM error. This is the little chip with the coding information for the big chip on the computer board. Well, probably…… The error codes are notoriously unreliable on these. The chip is available as a spare. If you are lucky, it clips into a holder; if not you’ll have to solder it to the computer board yourself. Tricky……
Power off before touching anything,
