Indesit WIDL126 Fault code 3 Ntc fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIDL126 Fault code 3 Ntc fault
  • #38046
    nelson
    Hello fellas, I called out to this one the other day, machine aborting wash, filling and emptying at the same time and dryer fan switching on whilst flashing lights 3 & 4. Checked my UKWG fault codes, NTC fault, tested the dryer ntc ok, tested the wash ntc not ok.
    Ordered both ntc’s and fitted them today, unfortunately the machine is still doing the same thing????
    Do these machines have to be reset? if so how? or do you think it may also have a fault on the module?
    Cheers
    #257505
    helo_75
    erm, itll need a pcb, and an eprom
    sorry, but its pretty common
    resetting thems as easy as unplugging and plugging back in
    #257506
    robbo1973
    Re: Indesit WIDL126 Fault code 3 Ntc fault
    have you tried nipping the edge connectors on the board as i have cured loads of faults like this all these machines are prone to these connectors being weak.i try this before anything else on these machines.
    #257507
    nelson
    Thanks Helo_75 & Robinsonrobbo,
    I did nip up all the edge connectors, I do it as a habit these days, wasn’t sure if there was some sort of reset button pressing mularky.
    But have to say my first thought was that the module had chucked the towel in.
    Thanks anyway, I’ll see if EMW might do this one, before we get into “might aswell just get a new one” prices.
    Cheers
