Re: Indesit WIDL126 Flashing Lights
“Pressure switch stuck on full”. It thinks it’s already full of water when it shoudn’t be. You need to check that the pressure switch clicks over when pressurised and that the air bell at the other end of the skinny air hose isn’t full of muck and goo. PCB failure is also a distinct possiblity, this being an Indesit and all.
Power off if you intend to investigate this yourself.
