Indesit WIDL126 keeps going
  • #58495
    mjw1208
    Got a customer with a indesit washer that doesn’t switch off durung wash prgramme ,a quick wash takes 90mins + instead 35mins etc, anybody got any suggestions as to what to check will it be pcb?
    #334708
    franz
    Re: Indesit WIDL126 keeps going
    Could be loads of things – start with water pressure or partial blockage in pump or drain hose or filter all could slow it down – unlikely to be module.
    Franz
    #334709
    Worth checking for O/C heater as well.
    #334710
    billyblue
    Could be a blocked pump, the drain hose pushed too far down the standpipe or an open circuit heater.
    #334711
    hodgheg
    …but unfortunately, chances are in the end it’ll be the module as they’re so unreliable. I think QER might re-con these, not sure.
    Richard.
    #334712
    mjw1208
    Checked heater and found it open circuit replaced it all ok now thanks for advice,
    #334713
