Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Indesit WIDL126 module connector block
- This topic has 6 replies, 3 voices, and was last updated 17 years, 9 months ago by
MickGeorge.
July 7, 2008 at 12:01 pm #37924
MickGeorge
ParticipantHi folks
After the small edge connector block that fits about midway on bottom of module.
It is an 8 way connector of which 6 connections are used 2black 2 red 2 blue (not sure if that uis the correct order)..
The 2 middle connections have shorted and been told by EMW that this is a common prob on these machines and a replacement connector block is available?..
Does anyone have a part no so I can order one up and does it come with wires attached or do I need a special crimping tool?… or is it a complete harness job?
Been told that this is a Mk4 type module fitted..
Mick
July 7, 2008 at 12:12 pm #257133Phidom
ParticipantRe: Indesit WIDL126 module connector block
I usually just cut out the damaged bit of block and solder the wires direct to the pcb.
July 7, 2008 at 4:31 pm #257134iadom
ModeratorRe: Indesit WIDL126 module connector block
Have sent you an e-mail Mick. 🙂
July 8, 2008 at 8:42 am #257135MickGeorge
Thanks for the replies guys..
Looks like the block itself is not availible as a spare part then?..
Did think of soldering wires on like you said Phidom but just wondered if there was a block available to save doing that.. I know its probley a better job than original but more trouble if module had to be changed again in the future.. just wondered if I could aviod if possible but looks like that might be the only solution…
Thanks for the e-mail iadom but was just after the conector block not a headache (smiles) but much appreciated as always.. unless there is a mod?
Thanks both..
Mick
July 8, 2008 at 10:12 am #257136iadom
The diagram I sent shows each individual harness part number. Having checked on one or two a price of £19.57 ex vat for five or six wires and two connectors is a typical Merloni rip off. 😥
July 8, 2008 at 4:26 pm #257137MickGeorge
Sorry Jim hadn’t got reading glasses on plus its these new hotpoint partno’s so didn’t recognise them as partno until you said.. still used to the 17**** no’s
Looks like it’s partno C00093717 but like you say – bit of a rip off at aprox £20 trade + vat.. might end up with the soldering iron after all…
Thanks again
Mick
July 11, 2008 at 3:57 pm #257138MickGeorge
Did solder this in the end – test to your soldering skills as the connections very close together but did as Phidom suggested and cut block to save soldereing all six wires…
Price of wiring harness part plus a special order was begining to make the job to long winded and customer was considering buying a new m/c..
Thanks for the help..
Mick
