Indesit WIDL126 Washer Dryer Error Code – LED 3+4 flashing
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIDL126 Washer Dryer Error Code – LED 3+4 flashing
  • #20155
    lees19981
    Fault occured when the machine appeared to fill itself completely with foam during the wash cycle and then turned itself off, on powering on at mains it now has the door lock led flashing quickly along with leds 3 and 4 both flashing together.
    Can anyone advise what may be the fault and whether this will be a costly repair?
    Any help would be very much appreciated
    Lee
    #186041
    Dave_Conway
    Re: Indesit WIDL126 Washer Dryer Error Code – LED 3+4 flashi
    Lamps 3+4 indicate a temperature control problem but why the over-foaming in the first place ?
    Did someone put the wrong type of detergent in the machine ?
    #186042
    lees19981
    Same detergent as usual, can only assume too much was used perhaps???? Would a temperature ontrol problem require a call out or could it be fixed by myself or by allowing the machine to cool down overnight?
