indesit widl126s drum bearing replacement sequence
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit widl126s drum bearing replacement sequence
  • #29922
    paulindesit
    I have an indesit washer dryer which the drum bearing has started moaning loudly. Its seems to be the inner drum bearing.
    My question is what is the sequence for removal?
    I could:
    remove the belt
    undo the main bearing nut
    remove the spider from the outer drum from the back. A bit fidely but possible.
    replace bearing
    The thing is… is this possible? Other than that it looks like a complete drum out the front and remove the spider etc.
    Also how do you remove the top/front panels. Are the screws hidden behind the bottom fron panel I haven’t looked yet.
    thanks
    paul
    #225204
    Re: indesit widl126s drum bearing replacement sequence
    paulindesit wrote:.My question is what is the sequence for removal?
    Oh, you are going to love this job? 😥
    The drum bearing spigot has to be removed from the outer drum in order to extract the 2 bearing and water seal. The Torz-headed bolts holding the spigot in place very tricky to remove and likely to draw blood (Have a first aid kit and nurse on standby 😉 )
    paulindesit wrote:The thing is… is this possible? Other than that it looks like a complete drum out the front and remove the spider etc.
    No you can’t get at the drum assembly or take it apart. You can only remove the drum bearing spigot! 🙁
    paulindesit wrote:Also how do you remove the top/front panels. Are the screws hidden behind the bottom fron panel I haven’t looked yet
    Front panel doesn’t come away seperately (its a 3-sided welded cabinet). The top panel easily removes with taking the screws off the back then sliding the lid backwards and off!
    Now for the bad news……Changing the bearing kit on one of these heaps of junk is not to be recommended as likely as not the actual drum shaft is damaged and acted primarily as the reason the bearings failed in the first place? At best the shaft and shaft collar need careful inspection and cleaning before reassembly. Liberally greasing with high speed grease in doing so. In my experience, and taking all possible precautions during the bearing change process, the new bearings will fail again in a matter of months!…. :rolls:
    Just my experience that is, but there you have it. 😉 😉
    #225205
    paulindesit
    I think you might be right. I’ll bin the machine and buy a decent one!
