Indesit WIDL126S flashing lights 1+2+4+Door Lock
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIDL126S flashing lights 1+2+4+Door Lock
  • #50123
    Shawza
    My indesit WIDL126S recently tripped the RCD in my distribution board when on the dryer function. After reading a few forums, it looked like my heater element had blown. I checked this and it was indeed the case. I changed this element and i am now getting the error code of flashing lights 1+2+4+Door Lock. From these forums, this appears to be fault F13. Does anyone know if this means that i need to now change the dryer motor? Also, should the dryer motor be on whenever the element is on? I dont want to change the motor then find out that it is something that is driving the motor that is not operating.
    Thanks for your help
    #303610
    Re: Indesit WIDL126S flashing lights 1+2+4+Door Lock
    dryer motor has to be running when element is on otherwise it will overheat
    Shawza
    Thanks dave – much appreciated. Im getting 240V at the coil of the motor but its not turning. I’ve order a new motor.
    #303612
    You need to make sure the fan motor will spin freely, its very common for the fan to come loose on the motor shaft and foul against the heater box.
