Hello
My Indesit WiDL126s is not draining
I have fitted a new pump and checked all the pipes are clear but it still will not drain.
The only thing I can think of is the powers not getting to the pump could anyone help ?
no I`ve tested it with the pump out to see if it is working but it`s not I put a electric screwdriver to the + and it`s only lighting the bulb very dim as though the powers weak ?
Check the pcb and looks ok all joints look good no burn marks etc .
Could you please point me in the problem fixing the pressure switch
ie what part of the machine is it whats it look like.
Thanks for any help
