Indesit WIDL126suk open circuit heater
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIDL126suk open circuit heater
  • #62395
    allan73
    The tennent at this job whose english is a little poor, has complained of this m/c not moving on from wash but also flashing lights on facia.I’ve found the water heating element to be open circuit which explains the not finishing but I did not think this would cause a fault code on this model or am I wrong ?
    Also the rear counter weight has broken & fallen off, which was not reported but again I can’t see any bearing on the fault code.can anyone offer any advise on this?
    Allan.
    #349922
    Allsorts
    Re: Indesit WIDL126suk open circuit heater
    IIRC the thermister has a timeout fault code and I would imaging that the heater not working would activate this… Also, check for damaged wires near the counterweight.. possibly earthing against the casing.
    #349923
    allan73
    Thanks for the reply Allsorts, I didn’t realise there was a time out fault code for heating on this model 😳
    Do you know if the hotpoint wf series have a fault code for this also ? I thought they just washed indefintely.
    Allan.
    #349924
    Allsorts
    The only thing I can say here is that some time ago I had the exact same model with a broken thermistor wire and it coused the machine to throw out an error code .. it was traced to one of the two little blue wires going to the thermistor.
    I would also check that your thermister is working.
    George
    #349925
    NTC fault will throw up an error code, OC heater will stick on wash cycle without error code.
    allan73
    Thanks for the replys, I’ll check the weight hasn’t damaged any wires when it’s dropped off.
    Allan.
    #349927
    gandh1
    iadom wrote:OC heater will stick on wash cycle without error code
    OR TRIP!!!
    #349928
    I would guess a short circuited heater might, no reason why an open circuit one would trip though. 😕
    #349929
    gandh1
    not all the time of course but ive had a couple of h/ps which were o/c and tripping too, guessing the breakage damages the insulation as well?
    #349930
    Also guessing that such a heater would register as down to earth as well. 😀
    #349931
    gandh1
    of course 🙂 although on those occasions it never tripped straight away, it was always a few mins into the cycle, i guess, when the element recieved power?, anyways i think the sun has got me – going back outside now for another fiddle as no-one on here atm seems to know how to fix karchers 8)
