Re: Indesit WIDL146
Error codes should be shown by these lights flashing slowly, not all stuck on.
Remember that those lights are option buttons, will they not cancel if you press them?
1+2 flashing is a communications error. If you unplug the machine from the mains and try and tighten up the wiring connections on both the console PCB and the main PCB in the base you may clear it.
If doing that or switching the machine off does not clear it then it does look as though the main board is faulty.
