indesit widxl 126 solenoid stuck?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit widxl 126 solenoid stuck?
  • #80872
    jim100
    Hi all I have the above machine and getting realy confused with it as it seems no matter which programme is set it wants to open the solenoid and take in water . If I set it to spin again water fills to washing level then it will try to spin won’t empty if I put it on a drain just wants to take in water like the programme has stuck mid way through a wash I’ve had both boards out and on visual inspection look fine. I’m pretty handy with a soldering iron so if it is a component I can change it out but not sure where to start a point in the right direction would be greatly appreciated one last thing I managed to lend another set solenoids but they seemed to do the same
    #414671
    Re: indesit widxl 126 solenoid stuck?
    Main PCB problem 🙁
    #414672
    jim100
    Any idea what the fault would be is there components i can change?
    #414673
    Jim100 wrote:Any idea what the fault would be is there components i can change?
    I’ve no clue, we send them off to EMW Electronics for repair.
    #414674
    jim100
    Ok cheers if anyone else knows where to start that would be great
