Indesit WIDXXL 146 Help require
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIDXXL 146 Help require
  • #71422
    vt1
    I am having Indesit WIDXXL 146 model however I am not able to find manual for it. I also noticed that it doesn’t have water filter at front bottom so I am not sure where I can find water filter for it.
    At this point of time, washing machine is stopping half way cycle and tripping the power.
    I also noticed water started leaking so feel something wrong with filter but I can;t find it.
    Please advice. Thanks
    #380993
    Re: Indesit WIDXXL 146 Help require
    It’s not the filter if it’s leaking.
    Also that wouldn’t cause it to trip.
    The leak may well be onto electrical components, such as the heater or motor and that would cause it to trip but you’d have to suss out where the leak was to begin.
    Its based on the Hotpoint WMA type drum, no front filter. The sump hose and filter can only be accessed from behind the lower back panel.
    But as already stated you need to find out why it is leaking and tripping, a blocked sump hose would be unlikely to cause that.
    Be sure to remove the plug if you intend to open it up.
