Indesit WIE 1375 washing machine fault code
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIE 1375 washing machine fault code
  • #83600
    erndog00
    Re: Indesit WIE1375 washing machine fault code.
    I seem to have a fault code flashing on the display of our machine which I can’t seem to find details on. Can someone please help?
    Fault code is -c0n
    Many thanks in advance.
    #423227
    clivejameson
    Re: Indesit WIE 1375 washing machine fault code
    AFAIK that’s not a recognised code, but these are shockers for throwing up things like that. More often than not it’s due to an earth fault (heater is prime suspect) but can also be a faulty motor or pcb i’m afraid. If it’s a faulty pcb that could equally be because another component has let go and taken the board with it.
    #423228
    erndog00
    Sorry Clive, don’t understand your AFAIK at the beginning of that post.
    #423229
    From memory of some posts a good while back this could be a failure of the condensation sensor. I have never encountered the fault or seen a condensation sensor but I’m sure I have read that they were fitted for a short time to some machines. I don’t know if it is possible to bypass this component. :con:
    Is the machine in a damp environment? If it is then a gentle blast of warm air from a hairdryer or similar from underneath may help. Tilt the machine back against a wall to do this, get someone to hold the machine and do not tip it back more than 35 degrees.
    AFAIK = as far as I know. 😉
    FYI correct model No: WIE137S ( for your information ) 😀
    #423230
    erndog00
    Thanks for the reply and update on the AFAIK … 😉
    To answer your questions, no it’s certainly not in a damp environment, and the machine is still operating properly, just with the error code on display. Lol
    I was aware of the incorrect model number when listed but couldn’t change it. 🙂
    Many thanks
