Re: Indesit WIE 157S UK Control panel PCB
The display module is a different part to the main power control module which is in the base. This is the £96 module that has the eeprom fitted, not the display PCB.
Two different display modules fitted, one of them is around £20 + vat, the other £55 + vat. The cheaper one is the later one and will eventually supercede the earlier one. The serial number of your machine will help to identify the correct display PCB, chances are that all stock of the old type have been used so the later one would suffice.
However to answer your last request for ‘any advice’……… bin it and buy something decent.
