i have an indesit wie157s, every time the program is started, an error “-con” flashes. it still runs through the cycle but this code worries me. any help with this would be great, maybe on resetting the machine or what the code means?
I’m sure someone else had this error some months back but I can’t remember what it was as the fault code described isn’t on any of the tech info as far as I know.
I think it relates to the conditioning rinse, hence the “con”.
Do you use conditioner Steve ? If not, try some and see if it’s still there at the end of the cycle 😉
thanks for the help guys, this machine is only 3/4 months old. it has since rectified itself and seems to be working ok, for just now. if it happens again it’s under warranty anyway.
