donmact wrote:The thing is, should it fill and empty on fault F03?
Well as you probably are aware, the NTC’s resistance reading will vary according to the temperature anyway. But at approx room temp (i.e 21degrees) you should get a resistance reading of between 19 and 25k ohms.
On the fill and empty issue, the electronics will always throw a wobbly when any component fails or shows an out of range reading. Likely as not in this case the NTC may be the reason??–don’t hold me to that though OK? :rolls:
Apart from NTC’s then heaters, dodgy motor brushes and the rest can cause the microprocessors within the module to have a dicky fit….all you’re left with is flashing lights and a headache to sort.. 🙁
All the best mate… 😀
