indesit wil 123
  • #22516
    rodric
    Hello!
    I’ve got problem with wasching maschine: inesit WIL 123.
    When I’ve runned it, it’s suddenely stooped at the final spin. That was with a lot of vibrations. Then, when I turned it again, diode from door lock start blinking (very fast) and diode under function button (spin 600-1200) also blinking and some noise cominng from maschine.
    What I can do???
    #195308
    jeremy
    Re: indesit wil 123
    call an engineer to look at it 😀
    look at repairs@
    #195309
    Re: indesit wil 123
    Unfortunately I fear that may not be much use to the OP, I suspect he/she may be in Germany.
    Moved to European forum.
    rodric, can you tell us which neon (diode) is flashing by number from the left, 1, 2, 3 or 4 ?
    rodric
    Re: indesit wil 123
    This is 3-rd LED from left side (with a symbol of spinning and number 1200-600)
    #195311
    Re: indesit wil 123
    Hi rodric, led 3 flashing is supposed to indicate that the thermistor, or water temperature control is faulty. However the fault codes on these budget priced Indesit machines can often be misleading. The noise needs investigating first. you should check that there is nothing in the drain pump or filter. With the machine unplugged, tilt it back against a wall and remove the plastic strip along the bottom edge. If your machine has a filter you will see it at the bottom right. Place something to catch the water underneath and remove the filter, look inside to see if there is anything inside the pump.
    If you do not find anything in the pump or filter then it may be time to contact a local engineer, or invest in a German made machine. 😉
    PS. Are you in Germany ?
    #195312
    rodric
    Re: indesit wil 123
    Yeah, I am in Germany, but I cann’t afford for Miele 🙂
    It suppouse to be a budget wasching maschine, because I am not pretend to stay here for whole my live 🙂
    #195313
    rodric
    Re: indesit wil 123
    Ok, Evrything is now working
    The problem was broken Electronic panel – now is new one and it’s working.
    Bye and thanx for all comments!
