Indesit WIL 133
  • #26001
    leveled
    The WIL 133 has become very noisy while on spin with a load of washing, but spins fine when empty The machine is less than two years old .
    Would this indicate worn bearings or is there something else I can look at Thank you
    #208421
    Re: Indesit WIL 133
    leveled wrote:Would this indicate worn bearings or is there something else I can look at Thank you
    Almost certain the bearings are shot, very common on these, 2 years is a long time for an Indesit….. :rolls:
    Other than that, the dampers and damper mounts are suspect and worth a close look…..?
    #208422
    leveled
    Re: Indesit WIL 133
    So is this repairable and at what cost, Our previous Indesits lasted 10plus years Thanks E
    #208423
    Re: Indesit WIL 133
    leveled wrote:So is this repairable and at what cost
    You can stick a new set of bearings in though they may fail after a similar period if not sooner due to inevitable damage upon the drum shaft (which is not available – only a drum assembly 🙁 )
    Dampers and damper fixings not too costly (2 variations of fixings) to fix.
    Cost wise?….To fix bearings about £100 in total Dampers £75 maybe? It depends on a number of factors including who may be willing to do it and how much they charge locally…? 😕
