indesit wil 145 1st, 3rd and 4th leds flashing!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum indesit wil 145 1st, 3rd and 4th leds flashing!!
  • #43964
    ElektroNi
    Hello.
    My whashing machine is displaying this error:
    Counting from the left side the 1st, 3rd and 4th leds are flashing.
    The door/power led is flashing too but much faster.
    Can anybody help my??
    #279243
    Re: indesit wil 145 1st, 3rd and 4th leds flashing!!
    No drain detected in the time allowed. Is there water still in the machine?
    ElektroNi
    No, theres no whater in the machine.
    Do you now how can i check the selonoide valve??
    One of them looks like it’s blowed.
    #279245
    Test meter – typical coil reading should be around 3.5kOhms when spilt from the circuit.
    Please consider what I said in the initial reply. If the water has gone and the machine thinks that it’s still full of water, it will fault. This would suggest a problem with teh water level control system. The pressure switch in these budget Indesits is rather prone to failure.
    Power off if you intend to investigate this further.
