Indesit WIL 153 Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIL 153 Washing Machine
  • #23716
    Lulubelle
    Hello!
    Does anyone know anything about this machine? I have a slight problem with it in that it won’t finish a program. It just washes and washes! We can stop the program and then manually set it to rinse, drain and spin (all of which work fine).
    It doesn’t seem to heat the water up either, so all of the clothes come out of the machine cold instead of warm (even if put through on a 90 wash).
    We are stumped as to what the problems might be, and we have had so much trouble with it that we are thinking of replacing it rather than call out the experts, especially if these problems look expensive. It’s all very annoying as the machine is only three years old (my old Servis lasted 12 years!) and has already had three visits from the repairer (last time was new brushes).
    Any advice would be appreciated, even if it’s just to go and get another one . . .
    TIA
    Lulubelle
    #199115
    Re: Indesit WIL 153 Washing Machine
    No heat should give an error code for failed heater, sensor, relay, continuity, any of the heat problems really. If it doesn’t, there’s almost certainly some sort of logic problem, which points at the (expensive) computer board.
    Lulubelle
    Thanks for that – our machine is not showing any error codes at all though – its one of those where all the lights blink a certain number of times, but none of the LEDs are blinking!
    TIA
    Lulubelle
