Indesit WIL 163S Sealed Tub?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIL 163S Sealed Tub?
  • #45523
    subs
    Got a call from a customer saying drum getting stuck. Sounds like sock or eco ball. Its quite a distance so wanted to make sure it was not a sealed tub job before i went.
    Subs
    #285987
    Re: Indesit WIL 163S Sealed Tub?
    Yep, sealed tub, had to write off a 14 month old one of these with a sock stuck at the back of the drum, couldn’t shift it. 😥
    subs
    Thanks Jim ill give them the good news!
    Subs
    #285989
    It depends where it is stuck, you might be able to fish it out via the heater or sump hose.
    subs
    Ive pulled all sorts out through the sump hole before but only if they are prepared to pay me for my time win or lose.
    Subs
    #285991
    johnnyj
    Removing the diispenser hose sometimes does the trick if it is stuck at the front,JJ
    #285992
    dpr1974
    What i’ve done in the past is use something like a metal coat hanger which i’ve straighten, then bend the end into 90 degrees and poke it through the holes in the drum in different places until i’ve snared the culprit, of cause this won’t work if it at the back.
    David
    #285993
    bzz67
    not sure but there maybe a gap under a drum paddle like on a wma’s
