Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Indesit WIL 168 -Door Lock flashing light problem
- This topic has 5 replies, 3 voices, and was last updated 18 years, 7 months ago by
Airspirit.
August 22, 2007 at 12:00 pm #29975
Airspirit
ParticipantI have an Indesit WIL 163 which was working fine until …. the door lock started to flash all the time, the door is closed properly, but when I want to begin a wash it refuses to start. The power is on, the pipe isn’t flexed and there appears to be no reason for the problem.
I would appreciated any advice on what the possible cause is and how to rectify it please. Is there a replacement part required?
Many thanks
August 22, 2007 at 8:16 pm #225382Penguin45
ParticipantRe: Indesit WIL 168 -Door Lock flashing light problem
The door may be closed, but is it locked?
August 24, 2007 at 8:25 pm #225383Airspirit
As I can open the door after I close it – I think that maybe … No, its not locked! :rolls:
August 24, 2007 at 9:08 pm #225384Penguin45
So – possible lock failure? No lock = no start for obvious safety reasons! Can’t find a WIL168, BTW – is it a 163?
Door lock for 163 is p/no 1603292, about a tenner last time I looked. Contact spares@ukwhitegoods.co.uk for confirmed prices and ordering.
However……… Due to the extreme fragility of the electronics, you may be best served to get your local independent in to have a look at it. Door lock failure can blow the computer board, by the same token, board failure can lead to no supply to the door lock :conf: .
Power off, if you are going to investigate further.
Penguin45.August 25, 2007 at 4:15 pm #225385iadom
ModeratorRe: Indesit WIL 168 -Door Lock flashing light problem
Can also be caused by a faulty door latch mechanism, the pin of the door latch can work up slightly, preventing the latch from closing correctly. This will also give the flashing door lock problem. Had one just like this yesterday. 🙂
August 29, 2007 at 6:11 pm #225386Airspirit
ParticipantRe: Indesit WIL 163 -Door Lock flashing light problem
Thank you both for your replies – I have “the man” coming round to sort it out on Thursday – I’ll let you know what happens!
Cheers
Jaki
