Indesit WIL103
  • #35548
    -vicky-
    hello can anyone help?
    have been to a Indesit washer Model WIL103, half way through the wash cycle the machine stops and gives error code flashing 1 & 3. 1 is delay timer and 3 is easy iron
    would appreciate if anyone could help with this
    thanks
    Home Appliance Ltd
    #247082
    Re: Indesit WIL103
    Are you registered for the trade parts of the site? You will find extensive info. on error codes in the Trade Technical Enquiries section.
    #247083
    helo_75
    however, lights 1 &3 suggests an f10 fault
    the machine isnt sensing the pressure switch
    pressure switch is an inexpensive part, but commonly its the pcb thats at fault, and with that youll need an eprom
    up to you which way you choose to go with it
    hope that helps
    #247084
    -vicky-
    thanks for the info will speak to the engineer to try the pressure switch
    vicky
