indesit wil103 going crazy
  • #24157
    keithwilliams
    called to simultaneous fill/pump out. thought it would be siphoning but no. not that easy.
    select a cycle and the machine begins to fill then pump runs continuously. the door lock light flashes constantly and the extra rinse and easy wash indicators flash as well.
    does this sound like a heater relay fault as in a similar post. or should i just sell them another (bosch) instead for an easier life.
    thanks
    keith
    #200897
    franz
    Re: indesit wil103 going crazy
    ntc short/open circuit – check ntc & module connections – although usually means new board required
    #200898
    If I understood correctly your fault is signaling by lighting diode the 3&4 reading from left. Assuming that light from spin is OFF than you have to manage F03:
    check first=
    franz wrote:ntc short/open circuit – check ntc & module connections
    Before trying to change entirely board check also Heater for earth leakage and after try to change phisical EEPROM. I had just once to change entire board but it’s possible.
    Baron 8)
