Got an Indesit WIL103uk. everything working except the motor.
It doesn’t throw up an error code which is strange as i normally find these flashing at the slightest problem.
Motor looks perfect, brushes are good ,armature has been cleaned etc.
its only 2 y’old & got little use as it was in house that was unoccupied for a long time..
Any ideas
Seamy wrote:everything working except the motor.
It wouldn’t necessarily show up as an error if there were a connection problem to the motor. Assuming you have continuity within the motor from the motor plug? Then plug the motor back in and try the same test from the module to the motor? 😉
