Indesit WIL103UK
  • #24219
    Going out Friday to this, customer says hubby has checked fuse and verified power to the mains filter. She says that the machine is completely dead, no lights, nothing at all. No warning, worked perfectly on last use.
    Don’t have any wiring diagrams for these, does it sound like main PCB or console module failure? 😥
    scots
    Re: Indesit WIL103UK
    Hi Just a thought, how did customer check power to mains filter. I remember a customer swearing that power was at machine. When I tested there was no neutral, the guy had used a mains tester you know the screwdriver kind.
    Apart from that it sounds like main PCB
    Brian
    #201180
    He is a spark Brian, not a close friend but I do know him.
    Jim, I think is monofase motor… I will send it to you in few hours (when I arrive at home), by mail
    Baron
    #201182
    Is allready send.
    I hope it will help you
    Cheers
    #201183
    Thanks Baron, just arrived. Unfortunately the motor was fine on this machine, customer has decided to invest in something a little better.
    The info you sent is very welcome though. I’m sure I will be able to make use of it in the future.
    Thanks again.
    Jim. :tup:
    #201184
    My pleaser…
    Note:I didn’t though that motor is faulty… I just said that model is with simply motor (monofase not trifase).
    See you
