Yes i know what your all thinking,anyway above model number fill’s for approx 15 seconds then begins draining,easy iron and delay timer light flashes along with the red neon,any suggestions.thermistor,heater and motor brushes ok,no blown tracks or dry solder joints on board.
Half a pound of semtex would probably cure it but not to be tried in doors.Any help would be appriciated guy’s.
Thanks for your reply martin,having found the related codes for the widl range lights 1&4 =eprom/set up error,can i assume that the epprom chip and the board will have to be changed.Qualtex out of stock so its of to emw in the morning.
