Indesit WIL123S problem-Error code light issue – Please help
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIL123S problem-Error code light issue – Please help
  • #18011
    Madgaz
    I have the indesit WIL 123 S washing machine. Once the cycle has been selected ( with or without a load inside) the washing machine fills with water as it should. After turning the drum a few times the power light starts to flash rapidly and the ‘daily timer’ and ‘easy iron’ lights flash at a slower rate. The machine then pumps out all the water and the light continue to flash.
    I have seen many posts like this but people seem not to describe how the lights are operating. I hope this information will allow one of you to help me.
    This has happened one week out with the warranty period, dam blast!
    Any help would be greatly appreciated!!!
    Thanks again.
    #177395
    Re: Indesit WIL123S problem-Error code light issue – Please
    From the left which option lights are flashing, by number ie; 1+3 or 2+4 etc ?
    #177396
    Madgaz
    The lights from left to right are 1 + 3.
    Cheers
    #177397
    1+3 suggest a water level control system fault, very ticklish electronics on these machines. It could be anything from a small hose blockage, loose connections, faulty pressure switch, control module etc. Other than the module most of the other causes are not over expensive. It may be worth seeing if we have an engineer in your area, try the link in my sig.
    Remove the mains plug if you intend to investigate further.
    Madgaz
    Thanks for the help, i have already had the machine in peices and reasembled it. Everything in it looks brand new still, no build ups, obvious blockages or burning on the boards.
    I have got an engineer coming out to have a look tommorow, he was recomended by a few friends, who all state that he is reliable and does not over price.
    I will post again with the outcome in case it can help anyone else.
    Again thanks for the help, forums like this are one of the true blessings of the internet.
    Gareth.
