indesit wil133 fault
  • #18117
    ryanjoseph
    I currently own this piece of crap. The most recent problem is that as soon as power is applied from the wall it fills with water, irrespective of whether or not i have turned the power on via the front panel. This will keep filling indefinitely. I am unable to get any lights to come on at any time, and also during the filling period no spinning will occur, again irrespective of switch positions. Software problem? Any ideas would be appreciated as i would rather not pay for the pleasure of someone to come out and tell me its not worth repairing. Many thanks
    #177755
    Re: indesit wil133 fault
    The fault specifically is a transistor failure on the computer board. If you can work out which one, it’s a cheap and easy fix. If you can’t, you’ll need a replacement board – £60-85 plus the VAT depending on version.
    Power off if you’re going to investigate.
