Indesit WIL133 keeps washing unless i move it on manually
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIL133 keeps washing unless i move it on manually
Viewing 15 posts - 1 through 15 (of 20 total)
  • #40523
    invisiblesystem
    Hi, I have a 2 year old INdesit WIL133 washing machine. One month ago it decided that it will wash all day and night and not move on to drain, rinse and spin. If I force it on manually it does all of this fine. But you have to manually change it 3 times which is impossible to live with. I’ve got a feeling it has stopped heating water as well. I ran it at 90oC with no clothes and couldn’t notice any heat. I noticed a lot of people calling this machine a pile of crap on these forums. I am gutted as a young struggling family and as the matching tumble drier and dishwasher I bought are also Indesit. I played with the plastic screws on the pressure switch. I don’t know if the selection knob for programmes is just a selector not a timer as well, I don’t know if the front circuit board may be faulty, or the bottom right back board which I assume is the controller – or if I need to sling the machine and buy another on ebay or try replacing the £10 pressure switchor what. Seems a shame and appauling for a 2 year old machine and I have enough debt problems as it is. Puts me off Indesit. Any help MUCH appreciated. Dan 07515 400362 😯
    #266651
    helo_75
    erm, the heaters the most likely culprit
    on the tub, below the main pulley
    a simple test with a meter will confirm this, plug out of course!!
    not sure it was a good idea to mess with the pressure switch though!
    #266652
    invisiblesystem
    Re: Indesit WIL133 keeps washing unless i move it on manuall
    yes i thought that after i did it! really? the heater can cause all of that? so order a replacement one i guess…. not too expensive (it looks like a kettle element yes?)
    i think i bought a meter not sure where it is and i have to be honest – i don’t know how to use one to test these things – any tips appreciated
    thanks
    dan
    #266653
    invisiblesystem
    just had a look – there are two wires and a small resistor looking thing with a nut that could be it? above lower puller round thing (below upper big one)
    i also noticed that there is a kind of fizzy noise from the back with the machine plugged in but off on the front – put me off leaving it plugged in…?
    i think i need to put a meter on those two wires and if it ‘beeps’ the element is ok and if not it is burnt out – am i right?
    many thanks for all your help
    dan
    #266654
    Element is located at the bottom of the back of the drum and should give a reading of 25-30 ohms when split from the circuit. Do not stick your fingers in there with the power on……
    With regard to quality, your choices are unfortunate – I’d have done without the dishwasher and spent rather more on the washer and dryer.
    Good luck,
    invisiblesystem
    could never go without a dishwasher – it would drive me nuts!
    thanks again 😀
    #266656
    invisiblesystem
    i ran a cold wash today and it was fine so you are right i think!
    element was £18!
    cheers
    fit it next week
    dan
    #266657
    invisiblesystem
    got the new element but the old one won’t come out – managed to break a pair of pliers and dent the washing barrel so far – just won’t budge and nothing to unscrew by the looks of it either HELP!!!!
    #266658
    invisiblesystem
    i just replaced the heater element in the indesit WIL1300 – it was a NIGHTMARE getting the old one out even after releasing the bolt nut – it was jammed hard and took a lot of jarring, pulling, bending and the metal that lips out over the rubber seal on the element had to be bent to get in there and force it out
    in contrast the new one slipped in rather too easily – i bent the lips (well top one which was the only bit i could get to) back into the rubbed but on starting the maching water leaks out and it looked like from the bottom lip/rubber side
    i can try to rebend again but looking like it may need a sealant and don’t really want to use e.g. araldite as will never get it out again and i doubt vaseline will do it!
    HELP!!! IDEAS ? thanks
    Dan
    #266659
    Please keep it to ONE thread only or it just gets messy and confusing.
    Duplicate posts will not get you more answers or any faster answers.
    Thanks.
    invisiblesystem
    ok but this is a new topic so i need to delete this one and start a new one please
    #266661
    No.
    Use the same topic and stop repeatedly posting the same message please on multiple threads.
    invisiblesystem wrote:i just replaced the heater element in the indesit WIL1300 – it was a NIGHTMARE getting the old one out even after releasing the bolt nut – it was jammed hard and took a lot of jarring, pulling, bending and the metal that lips out over the rubber seal on the element had to be bent to get in there and force it out
    Dan
    #266663
    It’s a story Dan, if the guys can see the whole story and not just bits of it dotted all over the site it’s a whole lot easier to follow.
    One problem, one machine, one thread.
    Multiple threads about the same machine or problem just confuse everyone by making it harder to follow the story and either I or the moderators will delete posts that have been copied and pasted into multiple threads.
    invisiblesystem
    do they go to it though if the header is a different problem? i guess it just shows another thread has been added? jsut that last time i added a new thread to it no one answered – and when i started a new one they answered straight away….?
    thanks
