Indesit WIL163UK Strange fault???
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Indesit WIL163UK Strange fault???
  • #36690
    whiskeyjack6058
    Went out to one of these today, S/N 610255509 80339671501
    Customer says that it skips part of its cycle out. After looking at it, I noticed that it fills up, then just stops and does nothing. However if I put it to a spin, it does it, and if I use the special programs they seem to work, or at least there is motor action. I put it back to a number 3 program (cottons) and it just fills and stops dead. SO… Heater checks ok (wilh a mega also) the motor runs ok and the pump runs ok, water valve is working and I have checked the pressure switch where I have a circuit when level up and a circuit when level down. I think its the module or perhaps the eprom on the module? Told customer to leave it disconnected from the mains for a few hours and to try again. Anybody got any ideas?
    Thanks,
    Robert.
    #251962
    bzz67
    Re: Indesit WIL163UK Strange fault???
    sounds like a module fault, i would get one in from EMW. if it was not the pcb you can return it , and it wiil only cost you £5 + vat. have a word with Tony at EMW, he’s pretty good with these faults.
    #251963
    You say the motor works OK but possibly you tried it without a washload? Dodgy brushes can give similar symtoms such as you mention. 😉
    #251964
    hotpnt
    hi, did you check both inlet valves? they can fill to a level from one, then switch to the second valve, but if its o/c it will just sit
    #251965
    whiskeyjack6058
    Hello again, I kina ruled motor brushes out as it did a spin lovely and it sounded in good fettle. Also, its only 14 months old and its an elderly lady who lives on her own.
    In relation to the water valve, its a cold fill only, but thanks anyway.
    Rob.
    #251966
    helo_75
    erm.. a cold fill only machine has more than one coil
    worth checking them both, some even have 3
    #251967
    whiskeyjack6058
    That is a good point helo_75. never even thought of that.
    I think i need to go back again and have another look 😳
    #251968
    whiskeyjack6058
    Thanks hotpnt and helo_75. I went back today and found one of the valve solenoids O/C. Pheww, glad I didnt order a module up.
    Thanks again.
    Rob.
