Indesit WIXE 127 fabric softener drain
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIXE 127 fabric softener drain
  • #64600
    norbellini
    i have taken out the dispensing tray and given it a good seeing to , but it still will not drain the fabric softener Whats next best bet, please.
    #357534
    Re: Indesit WIXE 127 fabric softener drain
    When you say it will not drain, is the softener still in the dispenser or is the dispenser full of water at the end of the cycle.
    If there appears to have been no water flushed into the fabric softener compartment then the conditioner fill valve may be faulty.
    If some water has gone in then the conditioner you are using may be too thick, try and use a free flowing one or water it down a bit.
    #357535
    norbellini
    the softener is still in the dispenser after last cycle and there is no water if it is the valve as suggested were is it and how do i check it It is the same softener the current wife has been using sinse machine was new, she tells me.
    #357536
    The inlet hose is connected to the valve, you test the valve in the same way you test any electrical component, with the mains plug removed using a megger or suitable multimeter.
    #357537
    norbellini
    thanks appreciate the help . I notice it has two valves were the mains water goes in .Is one for normal cycle and the other for the last conditioner cycle ,just like to know
    #357538
    Just a thought, have you looked up into the roof of the dispenser, if the holes in that are clogged then it will not flush in the conditioner either.
    One valve is the prewash valve, the other the main wash, not to sure of the set up on these but its likely that both valves are energised to effect the flushing in of the condensor so if one valve is faulty then it will not flush it in but still complete the cycle.
    #357539
    norbellini
    Thats great information thanks i put a multi across both solenoids and they both had continuity on ohms setting so i will take the whole dispenser out and check what you suggest
    #357540
    norbellini
    sorted i removed the water dispenser from the valve to the tray and found one small hole in the top bunged with gunge not really accessable without removing anyway this was the hole that filled the conditioner tray with water on the last wash . I t works fine now thanks all for the advise
