Indesit WIXE127 with failed bearings
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Indesit WIXE127 with failed bearings
  • #70465
    washersurvey
    Not mine, but a couple of indesit washers that were being tested as part of my research. They both had failed bearings.
    Are these a sealed tub or can the bearings be replaced? What would the cost of the parts (drum or bearings) be and how long would it take to do the job. If the machines are not economical to repair, does the motor, control board etc have any value to refurbishers. If so, how much would they be worth assuming minimum of 5 quantity?
    #378162
    Re: Indesit WIXE127 with failed bearings
    as far as i can see the answer is yes sealed tubs
    retail cost on the part shows at around £150 as a repair its a no go
    as for the panel prices since the tubs go a lot i would think refurbishers would have plenty of panels but i may be wrong.
    The only people who may buy the is QER as they refurbish panels
